View status of 2473s outlet from ISY
Is there a way that the ISY99 can see the status of a 2473S outlet when it the button is pressed on the font of the outlet. because now the outlet will turn on and off when pressed locally but the ISY does not see the status change.
Chris
Hello Chris,
Unfortunately the OutletLinc does not send a message when controlled locally.
Your only options are to poll the device every so often or use a different controller such as a RemoteLinc, ControLinc, a keypad button, etc.
Rand
Chris
