Ability to run a program manually
Hello,
It would be nice to be able to run a program manually if it didn't run and or if I wanted to run it again. Example is that I have the thermostat program run at 9:00am and sets the heat to 74 and when I look, my kids have manually raised the temperature up 3 or 4 degrees. When I see this from the ISY99i GUI, I need the ability to just run the program again as I set other values in the program and don't want to manually change multiple values when I could just click on the program and select "RUN NOW".
If not on you road map as a new feature, please consider adding this.
Mike
Running a program manually is already easily done: Go to the Program Summary page of the admin console, select the desired program, and open the right-click menu. There you will see a bunch of options, including Run (If), Run Then, and Run Else.
You can also do this via the html interface (//isy/pgms), and a number of the third party apps such as Mobilinc.
--Mark
The Wiki has more information about what these mean. Here it is in a nutshell, though:
  • [*:13kj97cb]Run (If) - Evaluates the condition in your If statement and runs the Then or Else part of your program based on whether or not the condition is true.
    [*:13kj97cb]Run Then - Skip the evaluation and run the Then part of your program
    [*:13kj97cb]Run Else - Skip the evaluation and run the Else part of your program
      37.4k
      374.5k
