ZOOZ ZEN31 RGBW Controller
Just wondering if anyone has used one of these controllers? How do you control the different colors? Thanks
Sent from my SM-F926U using Tapatalk
  • 1 month later...
I have a couple of these devices.  After you include the device you will see multiple nodes for it.  There is one called dimmer that controls the brightness and once called color that controls the different colors.
I setup programs that change the colors based on holidays and birthdays.  I havent setup any type of switch that controls color though.
Thank you for the response. So my plan was to add these around the kitchen countertops to replace my regular white LEDs. I was able to include it in my Eisy, but when I turn it on, it does not do anything. I will try to mess with it more to see why it is not working correctly.
pyrorobert, make sure that the color values are not 0,0,0 when you turn it on.  I have two of these controlling LEDs in the eaves of our house.  They always fall back to 0,0,0 on the color when I turn them on.  I set all my programs to turn them on then set the color.
