Insteon 2-wire 2474DWH LED bypass solution to not impact ISY signals?
I have one Insteon 2-wire 2474DWH switch at the end of a circuit that is a 2-wire with no neutral.   I know the 2-wire doesn't work with LED's it can't turn them completely off based on its design but was curious if anyone has success found a resistor bypass solution that would allow the 2-wire insteon to turn off my LED light.    There is no neutral in the light switch gang box but there is one in the light box for the LED porch light.
Please advise anyone has successfully found a solution and one that wouldn't impact ISY signals.  I am willing to try to see if I can use LED's otherwise this will be the only incandescence light in my entire house : )
Edited by tomas21
Update
I have seen other brand resistors also used. Designed for a two wire switch. With success.
