unable to upgrade from 0.7.4 to 0.8.88
I am not able to upgrade from 0.7.4 to 0.8.88. I am on IOX 5.5.9 and PG3x 3.1.24 on eisy. I tried reinstalling to the same slot but that did not work. I also have the same problem upgrading Weatherflow from 3.0.26 to 3.0.29.
Gary
Solved by GTench
Did you try to upgrade PG3 - There have been some issues with not being able to delete files in some versions
I am on 3.1.24 which I believe is the latest version
Bob is likely the better resource to ask here
I thought maybe PG3x 3.1.24 corrected the node server reinstall problem but I guess not. A delete and reinstall did work
I have not had this issue  - it may be an issue with your specific unit
Glad it is working again
Strange... Just got a notification that there is a new version available 0.8.88. When I look at the version that is currently installed it says that it is 0.8.89. Node server seems to be working fine though.
Correct - it is an attempt to limit simultaneous quering when you have a lot of devices - The YoLink MQTT disconnects if you querry too often - no other changes
Just curious but when I go to the node server store it shows the current version as 0.8.88 but my installation sys the I have 0.8.89 installed
I updates node info - it is a minor change addressing when you have a very large amount of devices installed - I cannot test if it works, as I do not have enough devices to test it
