About to install Yolink Node Server
Okay got some sensors that I was interested in with a Voice Hub. Everything is up and running very well and impressed with the range.
Question for @Panda88... What is the best way to install your Node Server. I'm buying it but should I do the trial first or will it not freak out just buying it without the trial? I've heard others had problems with the transition between trial and license on other node servers (a Polyglot thing I assume). Will wait for your input first before installing or purchasing.
TRI0N
Edited by TRI0N
As far as I am aware it should be ok to try first.  It is the same code.  When you purchase there will be an option to replace the existing (trial) node. Just PG3 handling the trial and it should be registered the same in PG3. I have personally done the same with other node servers without any issues.   I cannot really try myself as as a developer of the node  I am treated differently
Purchased and Installed without trial. It's working fine.
Cheers!
TRI0N
