PG3x version 3.1.25 (eisy) - OUTDATED
Hello all,
We are very happy to introduce PG3x v3.1.25 for eisy.
The eisy is using a new version of Polyglot version three called PG3x.  PG3x has infrastructure changes to make node servers (and PG3x) more secure.
For now, Polisy users should remain on PG3 and eisy users will use PG3x.
To upgrade PG3x:
In the Admin Console, click on Configuration, Upgrade Packages (note, this can take many minutes, depending on how long it's been since you last updated.).
After the upgrade is complete you should restart/reboot the eisy.  Do this from the Admin Console, Configuration, Reboot.
Once PG3x has restarted, reload /refresh the browser page.
Changelog for 3.1.25
 -  Add debug logging for setClientState
 -  Remove setClientState test message.
 -  Fix stopLogging - typo in config.logStreams caused duplicate messages in UI log display
 -  Fix working of update check failure message.
 -  Change 'ISY' to 'IoX'
 -  change ISY to IoX for installation target.
 -  Do timestamp checking for setClientState
 -  Rewrite the developer documentation. Lots of new content.
 -  Disable node server auto-updates.  Now displays "Update" button when new node server version is available.
 -  Auto update install URL with submit to store changes. [developer tools]
 -  Check for "null" devd entry
 -  fix spelling of storeEntry
 -  Delete debug messages
