Won't Update to 2.0
eisy, PG3x 3.1.25, IoX 5.59
PG3x tells me there's an update for Holidays Google.  When I click the update button, it shows that it's updating and restarts but the version doesn't change from 1.0.4 and eventually the message comes back that there's an update available.
PM me the PG3x log package (Log menu, download log package).
Then try going into the node server store, selecting the Holidays Google node server, click install, then click the re-install button and see if that works.
Logs sent.  Followed your steps, to install from the node server store then click re-install.  Messages show it re-installing but the node server still shows ver 1.0.4 after it starts.
I don't see anything wrong.  I did an update on my PG3 and it worked fine.  I never had a pre 2.0 version installed on PG3x but re-installing seemed fine there.
The only reason a re-install could fail is if there's a conflict between the version.  That's one of the problems using git repositories to distribute node servers, if the git command fails, there's no way to automatically correct for that. Deleting the node server and then installing it should get the latest version unless something is really messed up in the current installation. Of course you do have to re-authenticate and re-configure if you do that.
I have 2.0 installed but I can't get it to authenticate so maybe you don't want to update.
Smart suggestion.....  This is probably my favorite nodeserver and it works, so I am leaving it alone for the time being.
Thanks for the updates.  I think I'll just keep the version I have for now since it works and I have a lot of programs that use that node server.  Hopefully it will resolve itself at some point.
Authentication works for me on pg3, which is where I've originally tested it, but not on pg3x. I will take a look. As far as updating, I don't think I can help with that, other than removing and installing fresh. But wait until I fix authentication.
