could not match node type. 500 - Error opening folder bug?
Hey all,
I just updated my UD Mobile app on my Android to 1.0.35 about 2-3 days ago. Now I have a folder I had for a long time that will not open but pops up an error saying: "could not match node type. 500"  I can cancel the error, but I cannot access the folder contents.  Other folders are working fine.  I display in integer variable on the folder. I removed the variable and now it works. I put the variable back on the folder button and it throws the same error again. I recreated it to test what is going on after adding the display variable to the folder button, it is now throwing the same error message.
Obviously my work around is to display the variable as it's own button for now.
Solved by Javi
👍 Thanks!
