Weatherbit No Values in Polyglot
I saw some information about an issue with Weatherbit. Today, I have no values coming over to the nodes. The nodeserver is showing online, but all values are 0's. I've deleted and reinstalled in the same slot, but no change. Has Weatherbit changed something?
Solved by bpwwer
You may have exceeded the number of API calls your plan allows for in a day.  The free plan is quite limited. Or you may have asked for more forecast data than what your plane allows.
It looks like they may have reduced the number of days of forecast data you can get with the free plan from 7 to 6.  The node server gets stuck if it's looking for 7 days but only sees 6.
Thanks! I didn't change the settings that had been there for months, but they could have just begun to enforce. I changed the forecast days to 5 and the polling to 1800 and 42300 as suggested in the node. Let's see if it updates.
Bob, Weatherbit did restart sending data to Polyglot again. Thanks for your help!
