DaveStLou Posted April 24, 2023 Share Posted April 24, 2023 (edited) I have three of the 1st generation Insteon Motion Sensors 2842-222 that, in addition to Motion and Low Battery, report Dusk to Dawn in IoX. In IoX is shows "On" when light level is low and "Off" when light levels are bright. In my system I have this labeled as "Dark" In HA using the Universal Devices ISY/IoX integration this comes across and is showing up as a light class binary sensor (which makes sense) but the On and Off seems reversed which I think is because the light binary sensor class in HA says on means light detected, off means no light. I know I can flip them using a template, but shouldn't they be flipped in the integration since it will always show incorrectly for the 1st gen motion sensors? Below is history from one of my sensors which shows how this shows up: Edited April 24, 2023 by DaveStLou Revised screenshot 1 Link to comment
brians Posted April 25, 2023 Share Posted April 25, 2023 5 hours ago, DaveStLou said: I have three of the 1st generation Insteon Motion Sensors 2842-222 that, in addition to Motion and Low Battery, report Dusk to Dawn in IoX. In IoX is shows "On" when light level is low and "Off" when light levels are bright. In my system I have this labeled as "Dark" In HA using the Universal Devices ISY/IoX integration this comes across and is showing up as a light class binary sensor (which makes sense) but the On and Off seems reversed which I think is because the light binary sensor class in HA says on means light detected, off means no light. I know I can flip them using a template, but shouldn't they be flipped in the integration since it will always show incorrectly for the 1st gen motion sensors? Below is history from one of my sensors which shows how this shows up: Mine does the same, doesn't bother me because I use one in a basement hallway and another in a garage, both just to detect motion. I agree though it should be flipped. 1 Link to comment
DaveStLou Posted April 25, 2023 Author Share Posted April 25, 2023 7 hours ago, brians said: Mine does the same, doesn't bother me because I use one in a basement hallway and another in a garage, both just to detect motion. I agree though it should be flipped. I use mine to turn on lights when they are needed and off when they are not. I created a bug report: https://github.com/home-assistant/core/issues/92001 Link to comment
MrBill Posted April 25, 2023 Share Posted April 25, 2023 6 hours ago, DaveStLou said: I created a bug report: https://github.com/home-assistant/core/issues/92001 If you'll edit your bug report, and include "Link to integration documentation on our website" as https://www.home-assistant.io/integrations/isy994/ then the bot will use that information assign your issue. 1 Link to comment
DaveStLou Posted April 25, 2023 Author Share Posted April 25, 2023 4 hours ago, MrBill said: If you'll edit your bug report, and include "Link to integration documentation on our website" as https://www.home-assistant.io/integrations/isy994/ then the bot will use that information assign your issue. Thanks. I don't know how I missed that. Link to comment
Solution shbatm Posted April 26, 2023 Solution Share Posted April 26, 2023 Fix pushed. 1 1 Link to comment
DaveStLou Posted May 11, 2023 Author Share Posted May 11, 2023 Circling back on this thread: This is now working correctly. Thanks! Link to comment
