Moving from 300 to 500 series Zwave board and from 5.0.16C to 5.3.4
The steps are very simple, but I have one clarifying question.  Does the zwave back referenced in the 5.3.4 release notes need to be Normal or Full or does it make any differnce?  Also, I am upgrading from 5.0.16C and not a 4.x.x version but do not think that is an issue.
Z-Wave migration from 4.x.x branch
All Z-Wave nodes will be recreated when migrating from 4.x.x.  Some nodes will have different addresses, and some devices will have a different set of nodes.  In some cases, it is easier to rebuild your network rather than migrate.
1.  Before moving to 5.3.0, in 4.x.x, Backup your Z-Wave Dongle and then Backup your ISY.
2.  Replace the 300 Series Z-Wave board in your ISY with a 500 Series Board
3.  Install 5.3.4
EDIT:  I did Full backup and upgraded to 5.3.4.  Zwave appears good so far.  This is just stair on way to EISY tomorrow or Friday!  Even a couple of Schlage ZW 300 series of deadbolts are still working without any intervention and programs were fine.  I've got to do something with two zwave nodes that were added to my lighting.  I'll do search and then a separate post if I can't locate what to do with them.
Edited by hart2hart
