eISY admin console and PG3x confi in sync
hart2hart
I reinstalled Virtual nodeserver and the nodeserver did not retain the config including nodes and config.
The 5 virtual switch devices I created still exist in the admin console, but they are not listed in the nodeserver custom configuration parameters or as nodes.  I'm thinking I need to add them back on the nodeserver side.  Is that correct and is there a way to keep what is in admin console and nodeserver synchronized?
If you selected re-install to the existing slot, it does not touch the custom parameters so any that were previously entered will remain.**
If you delete the node server and then install, it will delete the custom parameters and you will have to re-enter them.
** This is somewhat dependent on the node server as it could clear them all at startup if that was part of it's startup process.
Thanks. I got interrupted during migration from pg3 to PG3x including the portal migration. Im 99.99% I did something wrong or out of order. I had to reinstall all nodeservers in their same slot and enter various parameters. They all worked except for this one.
It was odd how you config it and I can’t recall even the basics. I’m fine to recreate the 5 virtual switches but I don’t remember how it works and can’t find an example. I usually put this stuff in a document for future reference. But not for this or I can’t find it. Looking at its config screen again, there appears to be a missing section at the bottom. There is a header and then save button but no add another parameter button for that section.
Resolved.  I deleted ns from slot and added to different slot and then readded config.  Of course, I had to repair programs and UD Mobile as the links to old virtual switches were lost.
      38.2k
      381.1k
