Install vs. Upgrade
Thanks @bmercier , for making a Ring NodeServer available again.  The PGC version of it was a great tool for me to use motion sensors to control outdoor lights and I expect this will be even faster and better. I've just upgrade from ISY994 5.0.16C with 300 Zwave bard and PG3 on Polisy to eISY 5.6.0, Zmatter USB, and PG3x. Like always, everything UD is excellent -- especially the staff starting with Michel.
I never uninstalled the PGC version and was going to leave it in place as a resource for nodes and programming.  PG3x is offering upgrade from existing PGC version in its same slot.  If I do an upgrade in that slot will it likely keep the nodes the same — that would be perfect! …or should I install new version in a different slot …or do I need to just make good notes before the upgrade in same slot and then put all back in place. No worries either way.
Thanks again!
