Polisy with PG3x
Just a quick question (i hope)
I've upgrade my Polisy to following:
PG3x Version 3.1.27
Frontend Version: 3.1.27
IoX Version: 5.6.0
and now i keep getting these notifications, I know i can turn them off but did i miss something in the upgrade?
Pete
5/30/2023, 11:52:23 [pg3] info: IoX entry for Climacell::1 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Sun::2 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Timedata::3 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Holidays::4 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Push::5 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Ecobee::7 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Ring::8 OK
5/30/2023, 11:52:23 [pg3] info: IoX entry for Govee::9 OK
5/30/2023, 11:52:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DON
5/30/2023, 11:54:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DON
5/30/2023, 11:57:23 [pg3] info: Verifying node servers are installed on IoX correctly
5/30/2023, 11:57:23 [pg3] info: IoX entry for Climacell::1 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Sun::2 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Timedata::3 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Holidays::4 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Push::5 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for HolidaysGoogle::6 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Ecobee::7 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Ring::8 OK
5/30/2023, 11:57:23 [pg3] info: IoX entry for Govee::9 OK
5/30/2023, 11:57:26 [pg3] info: [00:0d:b9:59:45:9c_7] controller reporting command DOF
5/30/2023, 11:57:27 [pg3] info: [00:0d:b9:59:45:9c_9] controller reporting command DOF
@PeteEaston, I think we may have the same issue.  I'm working with the PG3x developer in the following thread:
I have PG3 notices turned on in UD Mobile and 3 times a day (at 7:01am, 3:01pm, and 11:01pm) I get a notice for each node server that they are connected.  The events are exactly 8 hrs apart.  Don't have an answer yet, but if you're having the same issue as I am, please come join our discussion.  It will help for Bob to know that I'm not the only one having the issue.  As a note, I have the same software versions, only I'm running on eisy.
13 hours ago, PeteEaston said:
@mbkingDid they figure out the issue?
@PeteEaston, no cause was determined for the connect notifications and for the last 2 days, I haven’t seen any of the notifications. So it’s still a mystery. Fortunately, it wasn’t causing any operational issues. If I see them again, I’ll post and I’ll review the logs.
@mbking thats good, i'm still seeing the connection for each node go down then back up usually two to three times a day. so glad it doesn't break anything
PG3/PG3x now does a pretty good job of recovering from network issues without it causing any visible issues. If node servers loose their connection to PG3(x), they'll keep trying to connect until they succeed.  If PG3(x) looses network connectivity or crashes, in most cases it will recover transparently.
But the way the notification feature in PG3(x) works is that it now detects these issues and reports them.  Chances are very high that these disconnections/connection events where happening all along and you just didn't know until it started sending the notifications.
In general, these types of events are being caused by external factors so the node servers and/or PG3(x) can't do anything to make them stop. But if PG3(x) is crashing periodically, causing all node servers to disconnect/reconnect it's good to check the log and report it as it probably is bug in PG3(x).
  • 4 weeks later...
FYI the new update seems to have resolved the issues
PG3x Version 3.1.33
Status: Connected
Frontend Version: 3.1.35
IoX Version: 5.6.2   Connected
