AttributeError: module 'pybalboa' has no attribute 'BalboaSpaWifi'
Just tried this node server. Installed ok and created two nodes - one for the connection and one for the spa. Yes, I set the host parameter to the IP address. But all the values are zero. In the log, there is a message :AttributeError: module 'pybalboa' has no attribute 'BalboaSpaWifi' when I try to set any value
I looked at the package on github and there is no pybalboa.py in the package. So then I searched github for pybalboa and found that in a separate project. It looks like that module has had extensive changes including deleting pybalboa.py and replacing it with client.py
So the question is - is there any active development on this node server and does the nodeserver need to be updated to use the new version of pybalboa or to have an old version of pybalboa included in the 3.0.0 version? Or am I doing something wrong?
Thanks, Andy
Edited by Andy P
