nodes are not showing up in AC
Using the solaredge_poly ns from the beta store.
Have the following nodes in PGx:
The nodes are not showing up in AC:
Have attempted to add all nodes but still nothing.
What am I missing?
I'm not familiar with the SolarEdge node server code, but typically, a node server will attempt to create the nodes on the IoX when it starts.  First try restarting the node server, it should attempt to add all of it's nodes to the IoX.
If it still doesn't work, we'll need log information (download log package from the node server log screen) and post or PM the node server author.
When PG3 tries to add the nodes to IoX, the IoX is responding with forbidden (http error 403).  The initial connection to the IoX is succeeding so it's not a problem with configuration and forbidden isn't an authentication error.
I don't know why the IoX would return that.
Have you exceeded the number of nodes allowed on the IoX?  I'm not sure what the limit is, 1000 maybe more.
12 minutes ago, Mecheng70 said:
I have 2.
Please submit a ticket.  The 403 error is not something I've encountered before and it's not something fixable in PG3, it's the IoX firmware.
