Fun and unsupported services
KSaccullo01
The minidlna server is successfully running in a jail on EISY. Onkyo receiver sees and plays music from EISY with no issue. The DLNA server does not look to taxing on the system with 12K songs. It was also complied on the EISY.
Anyone else have a fun unsupported application you can share?
I can outline more for you in a few days. It will be for the eisy. I dont know if it will work on a Polisy. The minidlan build (make file) is centerened around the eisy tremont processor. You may need to customize or try the package.
Do you have and nvne drive added to eisy? I don't want to touch the internal drive, too much.
Ok with ssh and all command line?
Ok with SSH and  command line?
I use disk labels when the creating the volume on the nvme. So any FSTAB notes will assume using labels
Know how to create a jail in freebsd? good reference.
https://clinta.github.io/freebsd-jails-the-hard-way/
OK if you brick your Polisy / eisy?
update:
Attached rough how to for installing mindlna on eisy.
Other thoughts for fun things to add:
zwave OTA update tool, homeassistant...
minidlna how to outline.docx
Edited by KSaccullo01
update
Thanks for putting this together, notifications don't always work for me and so I'm just now seeing this. After looking it over, I see it is beyond my ability and therefore risky for me to try, but I appreciate the detailed response.
      38k
      379.2k
