Two (dimmer) switches, same circuit, different lights -- Can I link?
I have a bedroom with a single (fan) light in the middle of the room.  I have access to the attic and want to install 4 of these (thin LED "recessed" lights) around the fan light:
https://www.amazon.com/dp/B07M68DL8F/?coliid=IVIWLLVRBLEYC&colid=15LWHGA04FA5N&ref_=list_c_wl_lv_ov_lig_dp_it&th=1
The fan light is controlled by Insteon (dimmer switch) and uses 2 halogen bulbs (my experience with LED replacements is that they die early, due to no heat escape I think).  The switch is near the door when you enter.
I want to put an Insteon (dimmer) switch on the opposite wall, adjacent to a closet.  I have power (to run the closet's lights) on the same circuit, neutral, etc.  This switch would directly control the 4 LED lights.
I'd like to link these two switches so that when one is turned on or off, the other does the same thing. In other words, when I use the switch connected to the 4 LED lights, they come on, but so does the fan light. Similarly, when I turn on the fan light, the 4 LED lights come on.  Dimming would be the same:  dim one, dim the other.
I assume it's no issue to link the two Insteon switches to do this, correct?  Any possible issues, say with dimming or anything else?
Notes:
I have a new EISY system.
I could use the single fan light switch to also control the 4 LED lights, by running the cable for the 4 LED lights into the fan box.  The problem is that I'd have to replace the fan box for various reasons.  That takes the project from a day or so to multiple days.
I also cannot run wire to where the single fan light switch is, as it's in a 4 gang box that is packed with 3 Insteon switches and 1 Zwave (for the fan), and so many wires that it's hard to fit everything in there.  (Meets code requirements, though, at least when the electricians did this.)
Notes:
Yes. It's no different than linking any other set of lights
Edited by lilyoyo1
Halogen bulbs may be a problem for Insteon. They are noisy. I would look into LED replacement again. But the installation you described is precisely what Insteon excels at.
Edited by Goose66
I had not heard that before.   Can you please explain why/how  they are noisy?
Edited by ELA
I personally have not had any Insteon issues with these halogen bulbs.  They are, however, the only incandescent lights I have in the entire house (other than in appliances), and I only have them because LED equivalents tend to die quickly in this enclosed space.
I do see that some of the new LEDs say they can be placed in an enclosed space.  So, I may try again.
In terms of turning on/off Insteon lights, I haven't had issues.  I'm not sure about dimming, because even though I have a dimmer switch on the halogen bulbs, I've never actually dimmed them.  (In fact, that's WHY I'm adding 4 LEDs too -- there's not enough light, so no need to dim an overhead fan light.  Once I have 5 lights in the room, maybe then I'll dim.)
Sorry, I was seeing “halogen” but for some reason reading “fluorescent.” Just a brain ****.
