State Variable - Doesn’t trigger from Favorite
I have a state variable that I use to indicate if home or away on vacation that I have various programs use. If I change the variable from the UD Mobile Home->IOX System->Variables menu it triggers the various programs on my ISY just fine. So I decided to put the variable as a favorite with type default.  When I change the state variable from the favorite screen/menu it doesn’t trigger programs in the ISY, only when I change it at Home->IOX System->Variables.  Weird. Is this a bug in UD Mobile favorites?
Edited by jwagner010
When clicking the Default favorite for a variable or when clicking on the home screen the same "Node Dashboard" is opened so I don't believe it would have nothing to do with Favorites.
My guess is the variable already changed so a Status change was not triggered.   Can you verify Variable status is enabled in UD Mobile> Settings Tab> Systems> System Name > Program an Variable Settings?
Yes it is enabled.  Works without fault from Home Screen just not from favorites.
Does the "Time of last change" update after the variable valve is changed?
Please post a screenshot of the favorite editor screen from Favorites Screen> edit (pencil icon at top) > click favorite tile > edit.
