Zigbee - Confirmed Working Thread
ShawnW
Posted (edited)
Smart Plug,DOGAIN Zigbee Smart Plugs Outlet Works with ST and Echo Plus Hub Voice Control Compatible with Alexa and The Google Assistant (Hub Required)(2 Pack)
https://www.amazon.com/DOGAIN-SmartThings-Compatible-Assistant-Required/dp/B08G46WWBB/ref=sr_1_1_pp?keywords=smart+plug&qid=1699711279&s=lamps-light&sr=1-1
Works well..  I do have an issue where this plug is turning off every 40 minutes or so. I do not have any programs that turn it off...  I created a sVariable to flag when it turned off and to immediately turn it back on until I can figure out why it is turning off..
I linked my second switch to see if it also turns off after 40 minutes or so and it does. My program fix works to ' keep it on ' so I am ok with this. I selected these because of their size being small enough to plug in to an outlet on my porch. This outlet has the spring loaded covers you have to open in order to plug a device in to them, but since mine are far enough under the porch roof they are protected from all but a rain storm with heavy winds blowing directly toward my front door.
Edited by Jim P
I got a Sengled E11-N1EAW Zigbee Light Bulb that's "'kinda" working but especially in the AC it seems a bit buggy.  So far I've been able to use programs to turn it on and off and change colors.  See
for more detail on the steps I've been taking and what I'm seeing in the AC.
-Grant
Posted (edited)
Got a Tuya Zigbee water sensor, It paired and added a node. The interview found a number of parameters but so far the parameters are blank and even though I simulate water, the state does not show up in the admin console. I have restarted the admin console. Tue, Nov 14, 2023 at 10:06 PM.pdf
Edited by photogeek54
Add photo
      38k
      379.4k
