Version 2.0.9 of the Ambient node server is now available (please read)
This version fixes an issue where the node server would fail if the number of sensors exceeded 9.  While trying to create a sensor node for the 10th sensor, it would generate a node address that was invalid causing the IoX to reject the node.  The node server would then get stuck waiting for the node to be created.
Version 2.0.9 of the node server uses a different method to generate the node address so that it will no longer generate invalid address, however this also means that it breaks any programs that used the old sensor nodes.
After upgrading to this version you will have to update any programs to use the new nodes and manually delete the old nodes from the admin console
@bpwwer I upgraded Ambient to the 2.0.9 in PG3x 3.1.36.  Station online status in lox is false. I restarted the node server in PG3x and still see the same status. PG3 x shows it as running and UD mobile notifications say it is online. All the new nodes show up in PG3x dashboard. I have attached an error log. Getting parsing errors name ' raw' not defined.
It also took the name from my Ambient weather station and added a new node in the proper slot to loc with all the new nodes. Can I just delete the old Node in lox?
AmbientWeather_7-17-2023_63318-PM.zip
Edited by tlightne
I updated from 2.0.8 to 2.0.11 with no issues.  However, I expected to see new nodes and there are non in the AC.  The old nodes are there and updating with the new version of the software.  The log looks normal.
@bpwwer, should I be seeing new nodes?  I only have two sensors; an outdoor sensor and an indoor sensor with multiple attributes in both.  The node addresses didn't change.
Thanks so much for latest update!  I am seeing everything i wanted to now. Seems to be working great!
Thanks again!
