Zooz Zen72 Dimmer: Don't see Multi-Press w zmatter
Hi
I am testing zooz Zen72 smart dimmer.  This is designed to control scenes/devices via 2, 3, 4, 5, up/down presses. I have set zwave parameter #13 to 1 per...
Quote
Enable/Disable Scene Control
Parameter 13: Enable or disable scene control functionality for quick double tap triggers.
Values: 0 – scene control disabled (default). 1 – scene control enabled.
Size: 1 byte dec
https://www.support.getzooz.com/kb/article/538-zen72-dimmer-switch-700-advanced-settings/#:~:text=Parameter 13%3A Enable or disable,for quick double tap triggers.
However in eisy I do not see these are triggers in programs, not as possible controllers in scenes.  eisy simply brings in the dimmer as a single device/node/entity
Does isy not support this functionality?
Edited by ccclapp
add link
To clarify, you don’t see options in programs for multiple presses ?
Iox doesn’t support this in scenes, only in programs.
