Add Harmony Remote icons
Hi
im setting up so I can use UD Mobile as a remote. It would really help if there were many more icons like the Apple logo, Netflix, others. Is it possible to add these?
Solved by Javi
  • 2 months later...
So I’m now using this functionality and sometime the link works and other times it doesnt
im assuming there is a size limitation or colour limitation. Would appreciate any insight you can provide. Looked at wiki and didn’t see anything.
Next question. When I click on watch tv. I want it to execute a harmony remote activity (Watch TV) plus move to a new folder. Is there a way to do this?
2 hours ago, Envirogreen said:
And now it works. Seems like I need to take it out of edit mode
Great
Currently not possible.
Folders do allow display Nodes which can show status and sometimes execute a command when the top of the tile is pressed, however the command must be tied to the status value for this to work. Commands on folders are not currently exposed to users.
Here’s how I worked around this limitation
biggest issue is that the url images change all the time. I’m assuming it’s a defect, annoying but not that big a deal
Each remote should have same icon  Apple should have the Apple logo  hopefully you can understand the issue
Edited by Envirogreen
Sounds like a bug.  Please send me a Private Message with a copy of the UD Mobile backup file or Open a ticket with and attach a Zipped copy of the UD Mobile backup file.
Also note that if you have any advanced icon configurations they have a higher priority to Favorites Icons, so Advanced icons must be deleted.
