Updating ELK Nodeserver Failed in iOS UD Mobile
I tried for the first time to update a node server from UD Mobile and I received the following error message:
The node server disconnected and did not update.  Using the PG3 web interface, I restarted the node server and it restarted with the old version.  A re-install was successful.
I have version 3.2.1 of PG3, so there may be something new there that caused the problem.
Hi @mbking,  I'm trying to replicate this issue.  Are you using a beta build of the Node Server?
@Javi, it was a production version. I’ll try again when a node server needs to be updated.
