Update after Upgrade
Jim, I upgraded to PG3x Version 3.2.3 Frontend Version: 3.2.3 IoX Version: 5.6.4 over the weekend and as instructed re-installed all of my Node Servers from the PG3 menu. I've found that iTach version 2023.01.09 [Beta] was the only version of the NS that PG would install not 2023.01.9. the one custom entry (a Power ON test string no longer works although it shows up in the "Main" tree.
iTach-IR_9-5-2023_30701_PM.zip
It looks like the Node Server could not connect to the URL.  Is the URL correct?
Javi, I need to take a brief respite from my tasks until our location cools off a bit, the current heatwave that we're in followed by a perfect week of 75 F and 40% RH which is normal for this latitude, Its been 95+ with an RH which would typically be a cuss word and though I have proper Air Conditioning, visits outdoors suck the energy out of me. With the back Surgery I went through in 11 of 2016 has restored a few parts of my normal ability I'm very limited by the local weather conditions. I sorry for the delay of a response but most of my time this week has been spent horizontal. Please excuse my lack of functional ability that has caused my delayed response. (the word "sucks" comes to mind). I'll get back to you when I have some tolerable "sitting" time at my desk. And as always, thanks for being an obvious Professional in your field of expertise. Your actions  and diligence appear more often than as in past years :)
Javi, During the recent update to PG3 I was instructed to reload all of my NS's which I did. Something has broken ITach flex IR. After reloading this NS I couldn't get my custom typed configuration parameters (1) to be transferred to IoX I only had two functions, discreet power ON and OFF, I cut the string down to only "Power ON" and only the example ported over to IoX. I had saved the working string to Notepad after I tweaked it, it had been fully functional on the previous PG3. I'll attach the log. Thanks for your help in advance.iTach-IR_9-7-2023_25439_PM.zip
I also neglected to tell you that I can't seem to be able to install your latest NS 2023.01.9, I can only load 2023.01.09. I even "Purchased" another copy of .9 and installed it in a different slot and it came up as .09. Lastly I thought it prudent to attach my discreet ON command after I removed the OFF to see if two commands together created an issue. For the life of me I can't turn off BOLD after I pasted something from a NS screen. Thanks in advance for your help Javier -  Bill Olsen
function, code1, hexcode1, code2, hexcode2  "Power ON","sendir,1:1,1,40000,1,1,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014",,
There was no functional changes to the Node Server only version number from 2023.01.09 to 2023.1.9 as the the zeros were causing issues in PG3x parser.  It should be fixed now.
The IR code posted above works when tested, i.e. I see the blaster flashing.  It is possible the code is incorrect if it is flashing but does not work.  Were the Custom Parmas saved the code saved after it was entered?
