Program question: "time from last run"
Hello,
I'm trying to come up with a program that enables my 'OHD Alert' folder under the following conditions:
1. One or more garage doors are open
2. The door(s) have been open for over 5 minutes
2. It's dark outside
Here's what I have so far:
OHD Alert Folder
           Program 'OHD Open' is True
     And From Sunset
           To Sunrise (next day)
     And Time is Last Run Time for 'OHD Open' + 5 minutes
OHD Open (not located in a conditional folder)
           Status 'Garage / OHD-1 Sensor' is Off
     Or    Status 'Garage / OHD-2 Sensor' is Off
           Set Scene 'Garage / OHD Buttons (KPL Indicators)' On
  - No Actions -
The 'OHD Open' program works perfectly - the KPL indicators are always on when 1+ door is open, and off when all doors are closed.
The problem is that many times the 'OHD Alert' folder does not enable as expected. Last night was a good example and I grabbed screen shots of the Admin Console before playing around with the program. The first shows the program summary display - it shows the time is definitely between sunset and sunrise, the status of 'OHD Open' is true, and the last run time for 'OHD Open' is well over 5 minutes ago. Yet for some reason, the 'OHD Status' folder still evaluates to "False". The second is the screenshot of the 'OHD Alert' folder program (in case I'm missing something).
Program Summary: http://dl.dropbox.com/u/2382226/1.png
'OHD Alert' Program: http://dl.dropbox.com/u/2382226/2.png
Any thoughts would be great... Thanks!
-Brian
Hi Brian,
Last Run Time is an exact time.
Can you use a Wait within your program(s)?
I would suggest the folder conditions be limited to the schedule conditions and using the other conditions in programs.
Folder Conditions for 'Night'
Add conditions to limit when programs in this folder are allowed to run.
       From    Sunset
       To      Sunrise  (same day)
       Wait  5 minutes
       Send Notification to 'Text to Blackberry'
Rand
Hi Rand,
Thanks for the quick reply - I missed that the "last run" is specifying an exact time, and not a time range...
I think I'll simply use the wait command with the "OHD Open" program to set a flag after 15 minutes. Then I can clear the flag with the "OHD Close" program. The folder can then simply evaluate whether this flag is true. I think this is what you're suggesting...
- Brian
You can use a range (From | For) with Last Run if that works for you.
Hi Rand,
- Brian
