Can't up restart since upgrade to 3.9.0
I get the message of a successful restart, and it starts for a couple of seconds before stops
some of the log
2023-10-09 13:35:16,798 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2023-10-09 13:35:16,798 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.2 Starting... 2023-10-09 13:35:16,807 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-10-09 13:35:16,808 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/./elk-poly.py", line 10, in <module> 2023-10-09 13:35:16,810 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller 2023-10-09 13:35:16,811 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/__init__.py", line 3, in <module> 2023-10-09 13:35:16,813 MainThread udi_interface ERROR udi_interface:write: from .BaseNode import BaseNode 2023-10-09 13:35:16,814 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/BaseNode.py", line 7, in <module> 2023-10-09 13:35:16,815 MainThread udi_interface ERROR udi_interface:write: from const import NODE_DEF_MAP,ELK_TO_INDEX 2023-10-09 13:35:16,816 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/const.py", line 1 2023-10-09 13:35:16,816 MainThread udi_interface ERROR udi_interface:write: [200ms_Silence]", 2023-10-09 13:35:16,817 MainThread udi_interface ERROR udi_interface:write: ^ 2023-10-09 13:35:16,818 MainThread udi_interface ERROR udi_interface:write: SyntaxError 2023-10-09 13:35:16,818 MainThread udi_interface ERROR udi_interface:write: : 2023-10-09 13:35:16,819 MainThread udi_interface ERROR udi_interface:write: invalid syntax
2023-10-09 13:36:14,879 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-10-09 13:36:14,881 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2023-10-09 13:36:14,882 MainThread udi_interface INFO __init__:<module>: User=polyglot
2023-10-09 13:36:14,883 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot
2023-10-09 13:36:14,884 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/000db9533694_3
2023-10-09 13:36:14,884 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTM6MzY6OTQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IldBUk5JTkciLCJ0b2tlbiI6IkdTeiUqdz02NmhOMHlVWDUiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0IjoxODg4LCJzZWN1cmUiOjEsImlzUEczeCI6ZmFsc2UsInBnM1ZlcnNpb24iOiIzLjEuMjMiLCJpc3lWZXJzaW9uIjoiNS42LjQiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ==
2023-10-09 13:36:14,885 MainThread udi_interface INFO __init__:<module>: Loading interface module
2023-10-09 13:36:15,507 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2023-10-09 13:36:15,717 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2023-10-09 13:36:17,436 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2023-10-09 13:36:17,440 MainThread udi_interface INFO __init__:<module>: Loading node module
2023-10-09 13:36:17,441 MainThread udi_interface INFO __init__:<module>: Loading custom module
2023-10-09 13:36:17,442 MainThread udi_interface INFO __init__:<module>: Loading isy module
2023-10-09 13:36:17,442 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2023-10-09 13:36:17,443 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.2 Starting...
2023-10-09 13:36:17,452 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2023-10-09 13:36:17,453 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/./elk-poly.py", line 10, in <module>
2023-10-09 13:36:17,455 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller
2023-10-09 13:36:17,456 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/__init__.py", line 3, in <module>
2023-10-09 13:36:17,457 MainThread udi_interface ERROR udi_interface:write: from .BaseNode import BaseNode
2023-10-09 13:36:17,458 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/BaseNode.py", line 7, in <module>
2023-10-09 13:36:17,459 MainThread udi_interface ERROR udi_interface:write: from const import NODE_DEF_MAP,ELK_TO_INDEX
2023-10-09 13:36:17,460 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/const.py", line 1
2023-10-09 13:36:17,461 MainThread udi_interface ERROR udi_interface:write: [200ms_Silence]",
2023-10-09 13:36:17,462 MainThread udi_interface ERROR udi_interface:write: ^
2023-10-09 13:36:17,462 MainThread udi_interface ERROR udi_interface:write: SyntaxError
2023-10-09 13:36:17,463 MainThread udi_interface ERROR udi_interface:write: :
2023-10-09 13:36:17,464 MainThread udi_interface ERROR udi_interface:write: invalid syntax
2023-10-09 13:36:32,267 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-10-09 13:36:32,269 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2023-10-09 13:36:32,270 MainThread udi_interface INFO __init__:<module>: User=polyglot
2023-10-09 13:36:32,272 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot
2023-10-09 13:36:32,272 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/000db9533694_3
2023-10-09 13:36:32,274 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTM6MzY6OTQiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IldBUk5JTkciLCJ0b2tlbiI6IkdTeiUqdz02NmhOMHlVWDUiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0IjoxODg4LCJzZWN1cmUiOjEsImlzUEczeCI6ZmFsc2UsInBnM1ZlcnNpb24iOiIzLjEuMjMiLCJpc3lWZXJzaW9uIjoiNS42LjQiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ==
2023-10-09 13:36:32,276 MainThread udi_interface INFO __init__:<module>: Loading interface module
2023-10-09 13:36:32,987 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2023-10-09 13:36:33,197 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2023-10-09 13:36:34,890 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2023-10-09 13:36:34,894 MainThread udi_interface INFO __init__:<module>: Loading node module
2023-10-09 13:36:34,895 MainThread udi_interface INFO __init__:<module>: Loading custom module
2023-10-09 13:36:34,896 MainThread udi_interface INFO __init__:<module>: Loading isy module
2023-10-09 13:36:34,896 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2023-10-09 13:36:34,897 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.2 Starting...
2023-10-09 13:36:34,905 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2023-10-09 13:36:34,906 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/./elk-poly.py", line 10, in <module>
2023-10-09 13:36:34,907 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller
2023-10-09 13:36:34,908 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/__init__.py", line 3, in <module>
2023-10-09 13:36:34,909 MainThread udi_interface ERROR udi_interface:write: from .BaseNode import BaseNode
2023-10-09 13:36:34,910 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/nodes/BaseNode.py", line 7, in <module>
2023-10-09 13:36:34,911 MainThread udi_interface ERROR udi_interface:write: from const import NODE_DEF_MAP,ELK_TO_INDEX
2023-10-09 13:36:34,912 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9533694_3/const.py", line 1
2023-10-09 13:36:34,913 MainThread udi_interface ERROR udi_interface:write: [200ms_Silence]",
2023-10-09 13:36:34,914 MainThread udi_interface ERROR udi_interface:write: ^
2023-10-09 13:36:34,915 MainThread udi_interface ERROR udi_interface:write: SyntaxError
2023-10-09 13:36:34,916 MainThread udi_interface ERROR udi_interface:write: :
2023-10-09 13:36:34,916 MainThread udi_interface ERROR udi_interface:write: invalid syntax
Solved by Goose66
