The initial version of the node server (v3.0.4) supports the following devices:
Martin Jerry (MJ) MJ-S01 Switch (Switch)
MJ Plug V by MJ (Plug-in Module)
MJ US-SD-TC01 (Dimmer)
MJ US-FC-01 (Fan Controller)
MJ US-SS01 Switch (Switch)
MJ US-SS02 Switch (Humidity Switch)
Shelly 1 (Switch)
Device support is determined by the module name the device reports in the Tasmota discovery payload. You will see in the installation instructions and relea
How about the Seeed Studios Human Detection Sensor Kit?
https://www.amazon.com/mmWave-Human-Detection-Sensor-Kit/dp/B0CLDHZWV8/ref=sr_1_2?crid=1J0CY049L4L97&keywords=seeed+human&qid=1700578955&sprefix=seeed+human%2Caps%2C176&sr=8-2
I have got all the info i will post later of how i got tasmota on it, and all the info needed to make it work to this point. including the template that works, and the modified Berry Driver.
I am monitoring it in MQTT Explorer and its wo
