Thermostat Dashboard View
@Javi Thank you and it looks great. Especially in Favorites!
I’ve got Venstar Colortouch thermostats with requisite node server.
When thermostats are in Auto Mode, either we need the up and down controls for heat and cool set points to move in unison or it needs to display only one set of up and down control that affects both set points.
Otherwise the degrees of separation between the two results in having to know which to update. Not worst thing but not necessarily intuitive.
Thanks for the feedback. I think it may be more compatible for all thermostats to implemented this request as a separate view (thermostat #2 ?) in the future.  There are too many inconsistencies in Node Servers to automatically implement as some Node Servers do not map the Current Modes correctly, and some thermostats do not have a single commands for setpoint up/down.
To be sure I understand, you would like both heat and cool setpoints to move together?
Thank you and UDI for an excellent mobile application! Yes, that's the way thermostat native apps work and it does feel intuitive.   Maybe, we could use the Up arrow for Cool and Down arrow for Heat.
Edited by hart2hart
