GE Enbrighten 52252 Z-Wave Plus Smart Dimmer No Neutral Dimmer Command Issues SOLVED
My Insteon 2 wire (no Nuetral) device died and I installed the 52252 Z Wave device and it was found by my AC and showed up as 5 nodes but I only need the first to control it directly. I can send On and Off commands and they work. However I receive no status update, it always shows as Off whether I turn it on with a command or physically at the switch. Additionally nothing happens when I send a dim or brighten command and the set level does nothing but send an On command at 100% regardless of the setting I give.
Any advise? I found something on the net about setting parameter 29 to 1 to enable status but when I use the set configuration menu I don't think anything is happening even when I have it in linking mode.
Thanks in advance
Joe
Edited by joepoway
