Sengled E11-N1EAW Zigbee Light Bulb
Eisy IoX 5.7.0 .  I got a couple of these lamps and I can’t get them fully integrated and working in the AC GUI.  I choose “Zigbee/Add a Zigbee Device” to put eisy in Paring mode.  I switch on the lamp and it sees the lamp and starts an Interview.  It adds two nodes to the Network, “On-Off Switch” and “Color Hue-Sat”.  The Property Sheet for either node display the Property Sheet for Color Hue-Sat”.  There are no Actions for On or Off.  I can change the color by selecting a value for Hue and Saturation and pressing “Move To”.  Details as to how these Properties shown on this page interact/work would be nice.  But there is no Button for on and off.  So if I choose the On-Off Switch node and Zigbee/Synchronize/Update with Interview I get an On-Off Switch Property page/sheet for both nodes, Color Hue-Sat and On-Off Switch and now I can turn the light on and off but I can’t get to the properties to change the color.  And Identify just generates a can’t communicate error although it does communicate because the On and Off buttons now accessible do work.  However it does appear to work when using a Program Object to change the Properties.
Maybe this is just a loose nut behind the keyboard but does anyone have any experience/suggestions getting these Sengled lamps to behave like they should in the AC and maybe a crash course on Hue and Saturation and how the different Properties shown on the Color Hue-Sat work/do ?
Grant
Solved by ShawnW
Grant
Hi Grant @GJ Software Products.
  I don't know how to link to other forum pages, but here's a screenshot of the one where I explained how to use the Color Hue-Sat page. It's the fourth post in this thread:
As for your problem with the 2 nodes always showing the same and them switching back and forth, I can't help you there. I would definitely suggest that you Create A Ticket. Does NOT sound as if you're doing anything wrong.
Curious, despite this problem, are you able to use both nodes in your programs? I use these bulbs extensively in my programs and I always use 2 commands for them, first one sets the Hue-Sat, and a second line turns it on/off.
But ya, I would log a ticket and in the meantime read my post in the pic above to learn the methods.
Good luck - any other questions feel free to ask.
Shawn
Shawn
@pkauf
Hi Shawn,
Strangest thing, I let it sit for ~24 hours and now coming back into it the two Property Sheets display accurate, Color Hue-Sat with hue & sat values, and On-Off Switch with your typical on-off values/actions.  Everything seems to work.  I haven’t gone deep into Zigbee, I’m wondering if it had to retrieve a device profile from an external source or maybe build one before the nodes would display correctly in the AC and that’s what took time.  I got one more lamp, maybe I’ll make a video screen-capture of the association process when I install it.
Yes, two commands in a program, one for hue-sat and another for on-off worked/works fine; that’s how I’m doing it too.  Having the AC working is nice as I can now set values statically like sat & On Level and they stick (I hope).
Overall, now past the AC anomaly it looks like these lamps work with eisy and the Matter dongle.
Grant
The 1st bulb was Zigebee 3.0, I got 2 from Amazon.  I got a 3rd from Best Buy, Zigbee HA 1.2.1 .  I added the 1.2.1 without issue.  I then added the 2nd 3.0 without issue this time.  All is well.
