Nodeserver Request or Network Resource... For Control by Web Products
Flex
It would be nice to be able to take the output from a network resource "HTTP get" and port it into variables. The resource could be polled every 10 to 60 seconds or so.
Or
Create a node server for the Control by Web model X410 and model x310.
These guys have some really good I/O capabilities. These keep watch over my sump pump, among other things.
This is what the output of the network resource looks like;
HTTP/1.1 200 OK
Keep-Alive: timeout=60
Cache-Control: no-store
Content-Type: text/xml
Content-Length: 883
<?xml version="1.0" encoding="utf-8" ?>
<datavalues>
<digitalInput1>1</digitalInput1>
<digitalInput2>0</digitalInput2>
<digitalInput3>0</digitalInput3>
<digitalInput4>0</digitalInput4>
<relay1>0</relay1>
<relay2>1</relay2>
<relay3>0</relay3>
<relay4>0</relay4>
<vin>12.6</vin>
<register1>0</register1>
<relay13>0</relay13>
<relay14>0</relay14>
<relay15>0</relay15>
<relay16>0</relay16>
<digitalInput5>1</digitalInput5>
<digitalInput6>1</digitalInput6>
<digitalInput7>0</digitalInput7>
<digitalInput8>0</digitalInput8>
<oneWireSensor1>78.7</oneWireSensor1>
<oneWireSensor2>73.6</oneWireSensor2>
<vin2>10.59</vin2>
<relay9>0</relay9>
<relay10>0</relay10>
<relay11>0</relay11>
<relay12>0</relay12>
<timer2>0</timer2>
<utcTime>1700863615</utcTime
  • 3 weeks later...
Is there a way to get data from an XML file from a network resource command into an Polisy ISY variable. Is this something a node server could do? I know with the ISY 994 it wasn't feasible.
Cannot be done from Network Resources.
This can be done from a Node Server and is the correct way to do this.   You will not need to use ISY variables as a Node Server create nodes that can be used in programs.
Thank you for your response. It's good to know that a node server will work for this. However, I am not at all adapt at writing one. So could said node server be set up to poll a device, similar to what network resources would do, grab the xml data and drop that into x number of nodes?
Yes
      37.5k
      375.5k
