Error message on connection with ISY994
I get the following popup when I open the admin console:
I am running 5.3.4, have reformatted the SD card, installed an earlier system backup, and the error persists. If the Z-Wave and Elk modules installed, but it will not connect to the elk, and I am not using z-wave currently. I have been unable to add new devicesl, but can communicate thru the GUI to control devices, and my programs run, but cannot be modified.
What other information is needed?
Dave
Thanks, that worked. I know I have changed SD cards in the past, but I don't recall having to go thru this process. To be honest, home automation will never take off if users have to use a terminal session and reload bootloaders. I have an Eisy on order, I hope we are beyond this, I'm not really inclined to learn Home Assistant, it appears to have similar warts.
Dave
