Clear a mystery Off command?
I have a 2342 On/Off switch that works fine EXCEPT at 3:59pm every day, it receives a mystery Off command and shuts off.  The Membership info from the admin console only shows it being a responder to a mini remote keypad.  I'm attaching the links table for the on/off plug in question. Neither of the 2 INSTEON address devices in the table are currently installed in use.  Suggestions on fixing the mystery off command?
Solved by Techman
Try doing a factory reset on the switch, then a restore device.
It's also possible that there's a program that has a link to the switch. Take a look at your log to see what's happening at 3:59am
@Techman an old program it was!!  I forgot about an old program I had running last winter to turn a grow light on in the morning and off at - you guessed it - 4pm every day.  Ha!  That program has been disabled. Thanks.
