change lock code on schlage connect
guys,
I just added my schalge connect (zwave) lock.
works great, can lock and unlock.
but how do I change lock codes? I just can't find where...
thanks
using a eisy with the zmatter usb thing
wow. look around for 30 minutes. cant find it.
post here
30 seconds later: "what is the "users" button do all the way down? oh! lock codes!"
sorry for that :-)
I lost the ability to set or change user codes when I migrated from my ISY to EISY and assumed the EISY functionality was not there.  I see in the comment above the mention of a users button.  All I have are a series of fields to "Set Configuration" allowing me to chose a parameter number and set a byte value with a 4 byte maximum limitation.  This lock is included in a number of programs and was difficult to link to my ISY initially requiring me to physically set the lock next to the ISY to register it.  That has prevented me from removing and re-adding the device.  Is my lack of the "users" button a side effect of migration?  Will dropping the device and then adding it as new solve this problem?
When you migrate, you switch from 300 or 500 series, which doesn't use security communications to likely newer z-wave that uses S0 (I think). I'd remove it and add it again - you will need to enter DSK code to finish pairing.  You might not need to move it near eisy as newer z-wave modules have much better range.
@firstone thank you.  Removing and adding my locks solved the problem.  Now I can manage user codes from eisy.
