Can't select custom messages all of a sudden
This has been working up until maybe an hour ago.  I can no longer select the custom message from the Email/Notifications Customizations.  Here is the code below.  Both notifications (one sent to Pushover and the other UD Mobile) have selected message ID 9 to send.  If I run the code, it works.  But see the screen shots and you'll see that message ID 0 is the only thing I can now pick from.  What happened?
Front Door Lights ON - [ID 000F][Parent 0001]
        From    Sunset
        To      11:59:00PM (same day)
    And 'Motion-Sensor' is switched On
        Set 'Front Porch Lights' On
        // This is a Message sent to Pushover with an Email/Notifications Customized message.
        Set 'Notification Controller / Service Pushover UDEISYPO' Send Sys Custom With Params To KBM_iPhone Priority=Normal Format=None Sound=Pushover (default) Retry=30 Expire=60 Content 9 Notification ID (ID=9)
        // This is a Message sent to UD Mobile
        Set 'Notification Controller / UD Mobile' Send Message To Kent Sound 'default' Content 9 Notification ID (ID=9)
Solved by gzahar
This is the list of Email/Notifications I currently have.  I deleted a few. Does that matter that they're not in order of 1, 2, 3, etc.?
Yes, I found it will stop loading messages at the first non-used number.  It will not skip over unused numbers.  I just created messages titled spare for any missing numbers.
@gzahar you are correct!  When I filled in the missing message numbers with spares (see screen shot), everything worked again. I marked your message as the solution but this is really something that UD should fix. Give us a button on that customization page that renumbers when we delete something. Screenshot2023-12-24at7_37_20AM.thumb.png.bf897b1b05b455d2742cf82f98ab81ed.png
