how can I see which devices do/do not have direct communication with z-wave eisy?
good morning!
been looking around for like 30 minutes. where can I see which zwave devices have direct communication with the zmatter dongle? (and also see which devices do not have direct communication with eisy)
thanks!
that what I get with the zen72 in the same room as eisy
which value should I look at?
<nodeInfo>
    <node flag="128" nodeDefId="ZY066_1">
        <address>ZY066_1</address>
        <name>SS-Rangement-D</name>
        <family>12</family>
        <hint>0.0.0.0</hint>
        <type>4.17.1.0</type>
        <enabled>true</enabled>
        <deviceClass>0</deviceClass>
        <wattage>0</wattage>
        <dcPeriod>0</dcPeriod>
        <startDelay>0</startDelay>
        <endDelay>0</endDelay>
        <pnode>ZY066_1</pnode>
        <rpnode>ZY066_1</rpnode>
        <sgid>1</sgid>
        <custom flags="192" val1="0"/>
        <devtype>
            <gen>4.17.1</gen>
            <mfg>634.28672.40962</mfg>
            <cat>119</cat>
        </devtype>
        <property name="" uom="51" formatted="100%" value="100" id="ST"/>
    </node>
    <properties>
    </properties>
</nodeInfo>
and that's the zen72 that I believe to be as far from eisy
<nodeInfo>
    <node flag="128" nodeDefId="ZY059_1">
        <address>ZY059_1</address>
        <name>2e-Thomas-D</name>
        <family>12</family>
        <pnode>ZY059_1</pnode>
        <rpnode>ZY059_1</rpnode>
        <sgid>1</sgid>
        <devtype>
            <gen>4.17.1</gen>
            <cat>119</cat>
        </devtype>
    </node>
    <properties>
    </properties>
</nodeInfo>
Not sure exactly what it is you're looking for. If the devices work as expected and their status displays correctly in the admin console then all is good.
Zwave is a mesh network, alll a/c powered devices relay their data. There's is no way that I know of to tell if a device is communicating with the Zmatter dongle directly or via a relay in the Zwave mesh network.
everything works just fine.
curious to know if I have many zwave devices not in direct range of the zwave dongle. maybe I could move my eisy elsewhere for things to work better. maybe I could change the antenna for a high-gain antenna.
something like this: https://www.amazon.ca/wlaniot-Antenna-External-Connector-Security/dp/B07PZFV9NK
not because it works that it can't work better :-)
If "everythihng works just fine" then I think you're looking for a problem that doesn't exist yet.
If it's not broken then don't fix it.
