can't exclude or remove z-wave device
What's the device you're trying to remove? Is it battery or a/c powered?
Have you tried a  controller reboot
Edited by Techman
Did you put the blinds motor into the linking mode before trying to remove it?
Edited by Techman
placed the isy in exclude - then pressed the button - nothing
used the 'remove failed node' and get the above
Have you tried removing/exluding the device rather than just the node
Did you try rebooting ISY
Edited by Techman
not sure what the difference is - this is what the devices look like
i think this one was added twice - and i might have a battery problem - it should be fully charged but i powered it with the charging device and it might be responding - it might be that i included it with it plugged in and it is not seen as a battery powered device
lemme look at x-ray
Is the motor working correctly?
If you only have one motor and it's showing up twice, then try a reboot. If the reboot doesn't correct it then delete the duplicate motor entry.
Edited by Techman
using the motor control node
the device stopped responding so i was replacing it - worked fine for a week - then nothing - no responding at all - so i was going to replace it - after removing the failed node
Rather than removing the node, can you remove the device.
Are you trying to replace the existing motor with a new motor
yes - but have never used the replace on a z-wave
how do i remove the device rather than the node?
First plug the battery charger into the motor, then in the zwave menu click on remove a zwave device and then put the motor into the linking mode.
I'm assuming that your controller is a eisy/polisy and you're using the Zmatter dongle
oh - yes - i tried that - no response
i am using the eisy with whatever radio it uses for z-wave - i do NOT have 'zmatter'' enabled (whatever that is)
i do have z-wave enabled
tried exclude device with it plugged in - it excluded
might be the battery - i'll replace it
I had that happen with one of my motors, the self contained battery failed and I had to replace the entire motor.
Glad you were able to exclude it.  Is the battery removable or do you have to replace the entire motor.
the battery is its own unit - plugs into the motor - i have extra units that i can rob a battery from
