Can Envisalink-DSC node server co-exist with professionally monitored DSC system?
My DSC system is monitored by Alarm Relay. I would like to connect my alarm system with my EISY. Is this feasible? I have read that the Envisalink only supports one connection and wasn't sure if that would interfere with my desire. Does anyone know? Thanks
yes, envisalink won't affect your phone dialer.  I actually have my dsc connected to polisy via envisalink and I use alarm relay via a phone dialer.  If you want to use envisalink to report via IP to alarm relay and to connect to eisy, I don't think that will work.  Though you may be able to connect two envisalink units, not sure.
Thanks for the input. I went ahead and tried the setup with both Alarm Relay and EISY connected, and so far no problems!
Is the Alarm Relay connection an IP connection or phone connection?
