temp show 160F in App -but 61 on thermostat
My thermostat is set at 41F as heat point (permanent) - it shows correctly in node, and on thermostat.  However, temp shows 160F on node server but 61F on the actual thermostat.   Another thermostat works fine (running auto).  Is there a bug or has something changed - I think it worked fine before
Also - how it away mode working - It seems it only toggles on - how to disable it?
