3 way switch replacement help
I have replaced 15 single pole switches and 1 3-way switch before.  I am trying to replace another 3-way switch, and I am confused about the wiring. I am hoping that some of the folks can help me.
I have this multimeter if it's needed to check connectivity of the wires.
It appears that light fixture is coming into the first picture, down on the top right with the black and white wire. The left box is the j box that inteon switch controlling the load with its red wire will go.. red on the switch connecting to the black on the upper right. But....
I'm confused too, why black is connected to white on left wire nut. You're sure about that? The Insteon switch in the other box will not be happy, and likely not under warranty, if the black and white are backwards.
Edited by paulbates
So do the following:
Box 1
  • Upper right black/white wire pair.
    • White to white bundle
    • Black to Insteon switches red lead, cap together
  • Upper middle
    • red - cap off separately
    • black to black bundle
  • Insteon switch
    • Red to upper right black as noted above
    • Black to black bundle
  • Turn on breaker and test... do the lights come on?
    • If yes, add the switch to ISY
    • Configure as dimmer if its an i3 and you want a dimmer
Box 2
  • Cap red from box separately on its own
  • cap red from Insteon switch separately on its own
  • Black to Insteon switch black
  • White to Insteon switch white
  • turn on breaker, does switch show it has power, leds light up?
    • If yes add switch to isy
    • make it a dimmer if i3 and needed
    • create a scene and put both switches in, setting them each as controller
  • Test everything from both sides
  • Push wires in, mount switch, etc,
Edited by paulbates
Box 1
  • Upper middle
  • Insteon switch
Box 2
Thanks, I will try your suggestion.
Here is more troubleshooting:
https://photos.app.goo.gl/7wAVUEzkEmz4qmbG6
Note: I said it wrong near the end of the video that the one with high voltage is Black.  It's actually white as in the diagram above.
Edited by turbo2pointo
Thanks for the suggestion, folks.
I took the risk and set up box 1 as single pole switch to test my theory of the wires destinations.
Eg. attach the line to the switch, and the black from the top right to the load, and connect the neutrals as well, and it works as expected.
Once I confirm that, I rewire them as in this picture, and it works.
[URL unfurl="true"]https://www.support.getzooz.com/kb/article/1338-3-way-diagrams-for-zen73-zen74-zen76-and-zen77-switches/[/URL]
One thing I still haven't figure out though is why both travelers have voltage when the line is connected to ANY one of the wires that go to Box 2, even when I didn't complete the circuit or connect another other wire.
Ghost voltage in travelers on long runs in a 3-way circuit is common. Never used to show up in older incandescent lighting, but I have had problems with LED bulbs in 3-way (or 4-way) circuits where the line was at one end and the load at the other with long run travelers in between.
Edited by Goose66
Also, to clear up some confusion with the original photo, the black to white connection in box 1 is fine and normal in this type of circuit, except the white wire should have had a piece of black tape wrapped around each end (and particularly in the box 2) to signal to electricians doing after-work that the wire is being used as a hot wire.
Edited by Goose66
      37.8k
      377.5k
