Insteon link optimization.
Is there a way to delete all the links which are not managed and mapped by EISY?
Having moved to EISY and a working device/scene map.   Is there a way to purge all
the old links which were programmed into my 60+ devices and only have the ones
managed by EISY.   Some of the devices have ancient "hard link" from 2008 when
they were manually bonded/linked.
Solved by Techman
If you do a restore device. the link tables in the device will be rewritten with the link tables that are stored in the eisy.
You can check and/or verify your device link tables using the diagnostic option in the device's right click menu
i.e. show device links, after the table populates click on compare. That will compare the links stored in the eisy with the links stored in the device. If there's a link mismatch it will highlighted.
Edited by Techman
One way is to go to each device, factory reset it, and then "restore device" from the admin console, one at a time. I know that can be difficult for some devices, but do the ones you can
If I was uncertain as to the devices' link table content, I would do that.
(I still have some original lamplics in use for indoor Christmas lights)
