NVME WD Black Heatsink?
@Michel Kohanim and others in the know.  I want the best performance to cover my 18 node servers or should I say plugins.  Just saw your article about replacing internal eISY drive with high performance NVME SSD.  I'm all in and am going to opt for the WD Black linked in article.  Will we benefit getting version with attached heatsink and if so, will it fit in case?
Edited by hart2hart
5 minutes ago, jec6613 said:
No, your Eisy came with a thermal pad to use the external case as a heatsink.
Thank you.  Saved me from pulling it apart two times or ordering both and returning wrong one.
