Weather Alert Update Failure
It worked a week ago.  Only thing I did this week is update the Python Interface which is reloading all the nodeservers.  Maybe that caused the issue.
But in the logs I see weather alert update failure.
We are in active warning until 5am tomorrow so good day to test but I do have minor surgery today so wont be able to look at anything until tonight.
Log in debug mode attachedf
NOAA_2-16-2024_100636_AM.zip
Forgot there was also a pg3x update to 3.2.18 and that did reboot it.
No ISY updates.
It may be in the logs but my config info is below so you can get a test warning (until 5am Saturday)
KJYO
VAC107
It looks like they've completely changed the format of data returned by that query.  It's no longer returning the XML data that it used to.
It took some digging but I finally found this: https://www.weather.gov/media/notification/pdf_2023_24/scn23-122_atom_feed_transition.pdf
Shouldn't be too hard to update the node server.
Posted Fix worked.  Second I updated the alert came in
THANK YOU!!!
