New NetatmoWeather (station) Node Server using the new authentication is in Beta - Only works under PG3x
Hi
A new node supporting Netatmo's latest authentication is uploaded in the beta area.  Please give it a try and let me know if the authetication works
NOTE - the node server only works under PG3x - PG3 does not support udi's authentication handler (which is used)
You still need client_ID and client_secret but the node server will now take you to the Netatmo website where the data access is approved and then returned to the node server - suggest to install from PC.
The node server supports multiple weather stations (can be selected until configuration)
