February 22, 20242 yr Solution 3 hours ago, mrxmas said: What is the cost of the isy portal? 3 hours ago, mrxmas said: What is the cost of the isy portal? $39 for two years
February 23, 20242 yr The portal also provides these features integrate assistants like Alexa and Google home for verbally controlling eisy Geofencing Remote access to eisy maintenance features remotely: reboot, upgrade packages Creating other accounts for other users to access eisy features with different access levels
February 23, 20242 yr There are also a couple of plugins that require the portal, including Ring and a soon-to-be-released Nest plugin. These plugins utilize push events from the associated cloud services to provide near-realtime status updates obviating the need for polling. The push events are sent to a UD web server which is forwarded to the particular eisy or Polisy via the portal.
February 23, 20242 yr 2 minutes ago, Goose66 said: ncluding Ring and a soon-to-be-released Nest plugin. I hadn't thought about that one. I have the ring plugin and use the ring as a front motion sensor for premise lighting. I barely get out the door and the lights are on.
