How long do variable assignments / init take?
I have a program that resets values for reporting at the end of month day 1, so I can evaluate highs and lows in future days.  The last few lines curiously don't seem to work. However, after 2 months of testing, its clear the last few lines aren't executing. I'm thinking its taking longer than the 5 seconds I gave it, the day value changes and program dies before completing:
Assumption: that the variable assignments and inits don't take very long.
Sump Pump Monthly Values Reset PM - [ID 0047][Parent 001A]
        'TimeData' Day of Month is 1 days
    And Time is 11:59:55PM
        $Sump_Pump_Maximum_daily_Gallons  = $Sump_Pump_Gallons_Daily
        $Sump_Pump_Maximum_daily_Gallons Init To $Sump_Pump_Maximum_daily_Gallons
        $Sump_Pump_Minimum_daily_gallons  = $Sump_Pump_Gallons_Daily
        $Sump_Pump_Minimum_daily_gallons Init To $Sump_Pump_Minimum_daily_gallons
        $Sump_Pump_Minimum_daily_cycles  = $Sump_Pump_Cycles
        $Sump_Pump_Minimum_daily_cycles Init To $Sump_Pump_Minimum_daily_cycles
        $Sump_Pump_Maximum_daily_cycles  = $Sump_Pump_Cycles
        $Sump_Pump_Maximum_daily_cycles Init To $Sump_Pump_Maximum_daily_cycles
        $Sump_Pump_Monthly_Gallons  = $Sump_Pump_Gallons_Daily
        $Sump_Pump_Monthly_Gallons Init To $Sump_Pump_Monthly_Gallons
I just updated it to 11:59:45 and will look next month
The question, approximately how long should assign or init take?
Paul
This looks suspicious.  Agreed you may be changing the day and rerunning before it completes.  Do the values change right at midnight so that if it reruns, you would get the wrong results the second pass?   Nevermind, if the days changes it would not run again right away.
Edited by gzahar
