ST-Inventory constantly restarts after upgrade from 3.2.17 to 3.2.20
I upgraded my Polisy from 3.2.17 to 3.2.20 today and ST-Inventory keeps restarting about every 5 seconds. I tried reinstalling it after first deleting it and the same issue continued. Any suggestion?
2024-03-14 18:22:35 info: NS: Starting Node Server
2024-03-14 18:22:35 info: POLY: Interface starting
2024-03-14 18:22:35 info: POLY: Getting config from environment
2024-03-14 18:22:36 info: POLY: MQTT client connected
2024-03-14 18:22:36 info: NS: MQTT Connection started
2024-03-14 18:22:36 error: POLY: Config has logLevel: WARNING
2024-03-14 18:22:36 warn: POLY: Loglevel: warn
2024-03-14 18:22:36 error: NS: uncaughtException REPORT THIS!: TypeError: Cannot read properties of undefined (reading 'nodes')
    at Controller.onDiscover (/var/polyglot/pg3/ns/000db9560fac_8/Nodes/ControllerNode.js:50:29)
    at new Controller (/var/polyglot/pg3/ns/000db9560fac_8/Nodes/ControllerNode.js:37:9)
    at Interface._addNodeToList (/var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Interface.js:523:19)
    at /var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Interface.js:582:20
    at Array.forEach (<anonymous>)
    at Interface._onConfig (/var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Interface.js:578:18)
    at Interface._onMessageQueued (/var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Interface.js:361:17)
    at dataq.process (/var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Queue.js:28:26)
    at dataq.add (/var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Queue.js:18:10)
    at /var/polyglot/pg3/ns/000db9560fac_8/node_modules/polyinterface-v3/lib/Interface.js:336:26
2024-03-14 18:22:36 error: POLY: uncaughtException: Cannot read properties of undefined (reading 'nodes')
2024-03-14 18:22:36 error: NS: uncaughtException: Cannot read properties of undefined (reading 'nodes')
Solved by Javi
The latest version of PG3 added a permission for apps which access eisy which may be related.  Is this check box available on enabled in the Node Server's configuration on web?
