Node Server does not start
Hi - trying this node server, after installation - I enter in credentials, but the Node server does not start.
When I try to open the log for the NS, i get the following:  Any ideas?
Thank you,
Steve
https://192.168.1.15:3000/logs/00:0d:b9:5d:95:f0_12: 404 Not Found
Here is additional info from the pg3 log-
3/15/2024, 21:14:27 [pg3] info: checkLicense:: Schlage Valid subscription license found. Expires: 2024-04-16T02:51:32.000Z 3/15/2024, 21:14:27 [pg3] info: startNs:: Schlage finished update check 3/15/2024, 21:14:27 [pg3] info: [Schlage(12)] :: Starting NodeServer - Version 3.0.1 3/15/2024, 21:14:27 [pg3] info: startNs:: Schlage updating database (enabled, timestarted) 3/15/2024, 21:14:27 [pg3] error: [Schlage(12)] :: STDERR: Traceback (most recent call last): File "/var/polyglot/pg3/ns/000db95d95f0_12/./main.py", line 9, in <module> 3/15/2024, 21:14:27 [pg3] error: [Schlage(12)] :: STDERR: from schlagens import SchlageNS ModuleNotFoundError: No module named 'schlagens'
Edited by SteveT
update info
  • 4 weeks later...
@Goose66 - i will try, thanks.
Nope, no dice, still getting the issue where i cannot even view the log.
Edited by SteveT
Here is the tail of the log from the file system - as I cannot get it from the UI.
Thanks @Goose66
4/10/2024, 17:40:06 [pg3] info: [Schlage(20)] :: Exit cause code: 1 - signal: null
4/10/2024, 17:40:06 [pg3] info: startNs:: Schlage starting polls
4/10/2024, 17:40:06 [pg3] info: Starting Schlage Expire Check timer
4/10/2024, 17:40:06 [pg3] info: Checking if Schlage has expired
4/10/2024, 17:40:06 [pg3] info: Starting Schlage Info timer 0
4/10/2024, 17:40:06 [pg3] info: Starting Schlage Version Check timer
4/10/2024, 17:40:07 [pg3] info: set to expire on 2024-04-16T02:51:32.000Z
4/10/2024, 17:40:07 [pg3] info: EXPIRE CHECK: Schlage subscription expires in 5 days
4/10/2024, 17:40:21 [pg3] info: set to expire on 2024-04-16T02:51:32.000Z
4/10/2024, 17:40:21 [pg3] info: EXPIRE CHECK: Schlage subscription expires in 5 days
You may want to open a ticket. I think your PG3 must be corrupt somehow. The installation appears to either be incomplete or there may be a permissions error, but it seems it can’t find the main folder of the installation that contains the plugin code.
Edited by Goose66
